my build...
#22
FormerVendor
I dont believe it will work like you think it will.
You want LOAD to make the turbo spool, thats why guys with 6spds need 2 steps to build boost off the line.
3.73's and a tight stall between 2800-3200 seems to be the ticket with turbo trucks.
Def. go with a good gate. Size of the W/G depends on how low of boost you want to run.
I have a JGS500 50mm Wastegate and a JGS 560 Blow Off Valve
These are TOP NOTCH quality products.
Probably the best on the market due to the engineering behind them.
The BOV is about 220.00 and the WG is about 360.00
You might be able to utilize a smaller gate and or BOV depending on your specs.
A big BOV is good, it prevents surging.
#24
Truck Sponsor
looking at upgrading it... if I decide to keep the 3600 converter, lag wont be much of a problem I dont think. I definitely want to get rid of the gears though.... probably go back to some 3.73's, maybe even taller...
with the right setup, I dont think high 11's will be out of the question... with better than stock mileage on top of that
