My Jegs oil separators and...
my quest for no crankcase pressure under boost. I bought 2 of the Jegs oil separators, one to put inline with the procharger inlet that draws air from the pass side valve cover and installed the other inline with the pcv system. I hope this will keep any oil from being drawn into the procharger, intercooler and MAF sensor and also help keep the intake cleaner. Dont know if these will work but we will find out, thay were cheap, 40 bucks each. I also installed a check valve in the pcv hose to ensure when under boost, there is no build up of crankcase pressure and just to make sure added a breather to the oil fill neck.
Nice work, I'll be following this to see the results you get.
I used a check valve that was really meant for an EVAP system, it rated for exhaust parts so I figured it would be heavy duty enough to handle the oil fumes too.
I may be getting rid of my ulgly *** home made oil seperators if yours works out. You can see my check valve in-line after the last can in the system.
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
09-25-2015 12:36 PM
