My New CAI for RADIX, may be the best
#23
Suncoast creations is about 25 minutes drive from me here in florida... I myself had to have one of those hoods... Mine fit without any extra work , did yours? heres a link to mine on my 2006 2500HD http://chevytruckworld.tenmagazines....y.ten?id=11112
#24
Originally Posted by LBSBLOWN
I'm not shure yet I will have to do some more data loggin but it appears to have givin me .5 to .7 psi more boost on the top end (100mph +) and the Blower sounds louder and deeper than before.
#25
TOTM: January 2007
Originally Posted by TBSS
Not to rain on your parade (the hood looks fantastic), but doesn't more boost mean less flow?
#26
Originally Posted by j's01silverado
More boost before the compressor/supercharger is a good thing. Means you are putting more air into the supercharger. It is when boost increases for reasons after the blower like restrictive exhaust. That will raise boost and decrease overall flow.
If the original poster is experiencing 'increased boost' above 100 mph, to me, that translates into increased restriction at that point.
#27
Not sure that is what is happening. AFAIK, boost is a measure of flow and restriction of flow....and boost is measured in the same place regardless.
#28
#29
TOTM: January 2007
Yes, there is an increase in boost at the inlet point, probably the TB or j-tube from more air being squeezed into the same sized opening. The bottom line is that there is more air being forced into the supercharger and engine which will translate into more flow. If boost increases on pre-compressor side, it will always equal more flow because you are forcing more air into charger and into the engine. Also, you are making the setup more effecient because air is being forced in rather than pulled in by the supercharger. If you can increase boost effeciently, meaning cool air, then you can always make more power.
The turbo guys run up to 15 psi and generate more and more power even though boost is a meaurement of resistance. It just means there is more air pressure awaiting to go into the engine. More pressure awaiting to go into the combustion chambers will always translate into more power and more flow, IF the air is cool and the boost is made effeciently.
If boost increases because of a restrictive exhaust system on intake tract, then the supercharger is having to work harder to pull the air in generating heat as well. There will be more boost, but it will be less flow.
When I installed my Maggie, Magnuson had to install a 3.6 pulley on my 5.3 becuase all the crush bends on my 2.25" exhaust was causing a huge restriction. I fixed my exhaust and boost went from 7psi to 5.5. I then installed the correct 3.4 pulley, and had 6.5 psi.
