Need belt info for new Maggie
Old 08-03-2010, 03:30 AM
swift700's Avatar
Default Need belt info for new Maggie
Almost got my Maggie 1900 done on my truck today and realized that the belt is missing from the kit (along with a few other important pieces, ). Does anyone know what the belt number is for the stock pulley? Is it the Gates K061098?
Old 08-03-2010, 06:30 AM
OL' MAN's Avatar
Don't know about Gates, But Dayco #5061115 will fit it. It should fit with any pulley.
Old 08-03-2010, 07:57 AM
blownerator
BlownChevy's Avatar
did you purchase this new? If so call, we will send you the parts.
Old 08-03-2010, 08:36 AM
TX Tahoe Z71's Avatar
EDIT: Belt sizes for the Radix MP112, NOT the TVS
Pulley size -Belt Size -Boost psi.(apx.) - Goodyear# - Gates#
2.75" Pulley = 111.0 " Belt = 9 to 10 psi. - P/N=4061110 - P/N=K061110
2.8" Pulley = 111.0 " Belt = 8.5 to 9 psi - P/N=4061110 - P/N=K061110
2.9" Pulley = 111.5 " Belt = 7.5 to 8 psi. - P/N=4061115 - P/N=K061115
3.0" Pulley = 111.5 " Belt = 7.0-7.5 psi. - P/N=4061115 - P/N=K061115
3.1" Pulley = 112.0 " Belt = ---6--- psi. - P/N=4061120 - P/N=K061120
3.3" Pulley = 112.0 " Belt = 5 to 6.5 psi. - P/N = 4061120 - P/N=K061120
This is for the Radix MP112, hopefully Brian can chime in if it is the same for the TVS. And for belts, I run Gates and most people on the forum have good results with them. The Gatorback's too for grip, but they don't seem to last as long.
This is a 111.5" belt, which might be a little small for the stock pulley. Just look at the last 4 digits of the part # for the size.
Last edited by TX Tahoe Z71; 08-03-2010 at 11:15 AM. Reason: belt sizes for Radix, not TVS
Old 08-03-2010, 09:23 AM
blownerator
BlownChevy's Avatar
The 112 and 1900 do not share any drive parts.
Old 08-03-2010, 10:52 AM
So that means they have different belt sizes then?
Old 08-03-2010, 10:56 AM
blownerator
BlownChevy's Avatar
exactly what it means
K061098 is the TVS belt and K061120 is the 112 belt.
Old 08-03-2010, 11:13 AM
Tricky I will edit my above post so as to not mislead.
Old 08-03-2010, 11:49 AM
OL' MAN's Avatar
That Dayco # worked for me with the stock pulley and the current 3.1". I do have the old first (?) design tvs1900 tho with the j-tube. Maybe they took different belts? I've also got the 8-rib tensioner, maybe that makes a difference.
Old 08-03-2010, 12:40 PM
swift700's Avatar
Thanks for all the replies, guys. Yes, I bought the kit new. I'll have to go and buy the belt locally, I can't wait for too long to get one. I'll give Magnacharger a call and get the missing parts. So far I've been able to make things work but I'd like to fix it up right. I found both throttle body sensor wires to be too short so I have to extend 11 wires today and mount up the fuel pump.
RustyD
05-23-2016 07:04 PM
slimchevy2
10-04-2015 08:02 PM
Wolftrk99
10-02-2015 08:17 AM
old motorhead
09-29-2015 08:22 PM
murderedSS
09-27-2015 10:16 PM
Quick Reply: Need belt info for new Maggie
