Need info on FMU and the blow off valve PLEASE
Old 06-16-2008 | 11:07 PM
  #21
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by sharpshooter
Another ? man.With the Tial can you regulate your max boost level by changing a spring?
The boost on a blower is regulated by the pullie.. You might have to play with the spring so that the BOV doesn't open while in part throttle or where there is slight vacuun..
John
Old 06-17-2008 | 01:04 AM
  #22
kbracing96's Avatar
between blower and maf
No, you can't do it that way, or you are venting metered air into atmosphere instead of the motor and it will run rich. If you want to run it as a blow off and not a recirculating valve, then you have to have the MAF AFTER the BOV. You would need to make it a blow though MAF instead of the suck though like it is in the OEM procharger location. Make since?
Old 06-17-2008 | 07:21 AM
  #23
sharpshooter's Avatar
procharger set-ups are blow through mafs
Old 06-17-2008 | 11:15 AM
  #24
Baltimore Whore
Yes the pro set ups or at least mine and the 2 other gents are blowing threw the maf. The maf is almost in the stock location, is only about a foot from the tb. So there isn't any thing between it and the tb of the manifold..
John
Old 06-17-2008 | 11:53 AM
  #25
kbracing96's Avatar
John
Oh, OK. The one I messed with on an lt1 and a D1-sc on my buddies GTO both had the bypass after the MAF. Sorry for any confusion
Old 06-17-2008 | 03:07 PM
  #26
Baltimore Whore
Not a prob, ya had me thinking I was going to have and run the maf wires longer or repipe the BOV for a sec.....
John
Texas5.3_1251
03-05-2016 08:10 PM
walledition
11-13-2015 05:29 PM
MA$TER_E
09-09-2015 03:14 PM
11MPG
09-08-2015 04:52 AM
brandon_6667
09-06-2015 04:49 PM
Quick Reply: Need info on FMU and the blow off valve PLEASE
