Need some methanol compatible sealant
Old 02-27-2008, 02:45 PM
High on diesel fumes
thunder550's Avatar
Default Need some methanol compatible sealant
I need to seal up the fitting for my meth pump that is installed into the windshield washer fluid tank. I have tried RTV silicone, regular silicone, and JB Weld and they all start leaking after a couple weeks. Is there any type of sealant that is methanol compatible and won't degrade? I'm running 100% undiluted methanol.
Old 02-27-2008, 02:56 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
JB didn't hold?? You sure you used it correctly? lmao, holy crap. What about MarineTex or AVTex...I used to use MarineTex under water, it held to anything. http://www.marinetex.com/
Whether you're a beginner or an expert mechanic. For any project from repairing a surf board to repairing a damaged hull, patching a fuel tank, sealing leaky rivets, preventing marine fouling, enhancing the beauty of a teak deck or many other boat and home repairs, you can rely on our uniquely formulated polymer systems.
AVTex is similar
Old 02-27-2008, 03:24 PM
krambo's Avatar
I used "Amazing Goop" for the same application. Haven't had ANY issues. I chose this stuff because it bonds just about anything and also remains flexible so it bends, not cracks, when needed.
Link ---> http://www.amazinggoop.com/amazinggoop/index.html
Old 02-28-2008, 12:03 AM
thunder550's Avatar
Thanks guys, I'll look into all of those.
Old 02-28-2008, 12:07 AM
thunder550's Avatar
Bill, the JB Weld was rubbery and crumbled very easily when I pulled the fitting out of the tank. So much for hard as steel!
Old 02-28-2008, 12:12 AM
dirt track racer 81's Avatar
i got some of that amazin goop..holy **** thats some tuff stuff
Old 02-28-2008, 12:36 AM
Whippled2dr's Avatar
For my previous water/meth setup, I had a small 2 qt tank that I put a fitting in and used the "amazing goop" stuff. It never leaked, I even had 100% meth in it sometimes.
Old 02-28-2008, 08:27 AM
trever1t's Avatar
Where do you find the Amazing Goop? Sounds like some amazing goop, lol.
Old 02-28-2008, 11:37 AM
Home Depot has it. Lowes probably has it too. I used the plumbing one.
Old 02-28-2008, 06:35 PM
krambo's Avatar
That line is priceless!
Yea, I bought mine in HD, plumbing isle.
Quick Reply: Need some methanol compatible sealant
