Negative timing while shift
Hey guys im new to the turbo system, I was asking myself if its normal that the timing goes negative while shifting. My timing is at 9,10 on 6 psi but when it shifts it goes negative 9, 10. Is this normal?
2010 5.3 stock with a 76 mm turbo kit and a 3600 multi disk circle d.
Torque management is off on the motot still have it on the tranny (6speed)
Im tuning the truck, first time tuning a turbo truck, Was tuning the WOT part air fuel is around 11.5 11.7, i stop there due to the timing dropping when shifting.
torque reduction upshift. torque management.
i left mine on for a reason. others will say it's causing slow shift times or whatever. if set up right, you will notice zero difference at wot, and on the track.
Did't have time this weekend due to work, But earlier i tune the tranny i had the book for the 6 speed trannys here and i start it tuning. It help a lot timimg its not dropping any more i see it dropping like 2 degrees but feels way better
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
lxcoupe
07-14-2015 10:14 PM
