NEW Lingenfelter MAF for FI...
Old 08-03-2006 | 09:43 AM
Superado's Avatar
11 Second Truck Club
Default NEW Lingenfelter MAF for FI...
from e-mail newsletter:
New - Lingenfelter 100 MM Mass Air Flow Meter
The Lingenfelter high flow mass airflow sensor was designed as a replacement sensor for GM frequency type mass airflow sensor applications for LT1, LS1, C5 ZO6 and LS2 vehicles. This sensor also fits 1999-2006 Silverado, Sierra, Tahoe, Yukon, Escalade, H2 plus many other GM vehicles that use the frequency type MAF sensors
This is the same mass air flow sensor used in the LPE 600 hp and 725 hp 2005 -2006 C6 Corvette twin turbocharged engine packages. The LPE MAF solves the mass airflow signal drop out problem found on 2005-2006 C6 Corvettes that occurs under high airflow conditions. The large diameter, low restriction LPE 100 mm MAF sensor assembly provides accurate airflow measurement while producing very little restriction,
even at very high power levels. $299.95
several pics on website...more details as well...
any thoughts?
Old 08-03-2006 | 04:40 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
i've got that letter but has any one run it?? i think it would be good for turbos
Old 08-03-2006 | 05:17 PM
moregrip's Avatar
what a rush!
I want one please
Old 08-04-2006 | 06:42 AM
FlaBouy's Avatar
Wow
and just prior to me going to 2 BAR Speed Density due to maxing out the MAF
Good find.............
Old 08-04-2006 | 07:07 AM
cablebandit's Avatar
9 Second Club
still gonna max out the maf at the same hp...just less restriction. I run a descreened ported fbody maf
Old 08-04-2006 | 04:25 PM
parish8's Avatar
single digit dreamer
the truck maf is prety good. there is no "drop out". you do max it out at about 600fwhp and i am prety sure the new sensor will max out about the same time.
somehow fixing the 60lb/min max flow rating that the computer will register is the real problem once you start making some good power. if there was a way around that then maybe this sensor would make sence. till then i would just get rid of the thing and run it in speed density.
Old 08-04-2006 | 04:58 PM
FlaBouy's Avatar
Spoil sport....
Mine is pulling 64.55 lb/min at 12222 HZ @ 5800 rpm. My 2 BAR MAP sensor registers 184.5 kPA...And you are right..I am putting 650 ponies to the crank....So I guess it is time to dump the silly thing and go 2 BAR... BTW that is all without an intercooler...unless you count the meth kit....
lucas287
31
01-12-2021 06:18 AM
legerwn
56
11-15-2015 10:21 PM
JordanH
10-03-2015 03:59 PM
02AWDAWSDenali
10-01-2015 05:08 PM
ZxHybrid
09-18-2015 04:44 PM
Quick Reply: NEW Lingenfelter MAF for FI...
