New MSC front mount turbo almost done!
Old 10-08-2009, 08:44 PM
$nake Charmer's Avatar
Yeah I know I'm still running that crazy *** cam but it's actually working pretty good, and yes I still have the 4000 stall
Old 10-08-2009, 09:57 PM
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
what manifolds are you running??
Old 10-08-2009, 09:58 PM
turbocody's Avatar
Originally Posted by $nake Charmer
i guess im also wondering if i should run the wastegate into the atmosphere or back into the DP... any sugestions
deff run the wastgate to downpipe, i tried open to atmospshere and that didnt last long...lol
check your pm's
Old 10-08-2009, 10:02 PM
GMCtrk's Avatar
why?...........
Old 10-08-2009, 10:31 PM
I'm running some stock manifolds... And what didn't last long when you let the wastegate go into the atmosphere?
Old 10-09-2009, 12:18 AM
f4tal's Avatar
ya and that cam is huge. lol well for boost it is. idk what your cooling problem is but im interested to see what fixes it...
Old 10-09-2009, 12:29 AM
turbocody's Avatar
Originally Posted by GMCtrk
why?...........
Cause it was very loud, nothing wrong with doing it.......just WAY too loud for my liking.
Check your private messages snake charmer
Old 10-09-2009, 09:37 AM
f4tal's Avatar
lol ya it is super loud in boost!
did you ever get boost creep when you recirculated back into your dump?
Old 10-09-2009, 10:30 AM
Resident Retard
BlackGMC's Avatar
Yeah lol... But I just ran into an issuer with the coolant temp tonight... Can't keep it low, any suggesstions i'm already going to install a restrictor plate in the placE of the thermostat but would a 3 or 4 core radiator fix it?
So is it overheating? if so i might be because you completely removed the overflow tank and added that radiator cap to the top coolant line... That may not be the best setup, especially if the over heating problem started after all that was removed... I don't think a restrictor will fix the problem... Your truck being an 05 should have the big 34" radiator and efans... So not much to upgrade there, its gotta be the setup or the sensor itself... take off the oil cap and let it run if you get alot of steam out of the oil filler then you have a mechincal issue...
its a GT-67the cam is working well, but its probably the reason im making boost at idle... MSC is Main Street Customs. i will be running an intercooler but not until i can afford an A/W... im only running 5 to 8 psi... im running the stock fuel pump and no FPR
Who did the tuning? I have never heard of MSC before, but if you come out to the track again, i will take a look at your tune for you... Also I am assuming it is a 1bar tune?
Where did they relocate your IAT sensor? I don't see your MAF in the charge pipe so I am assuming that your not running one and your tune is setup for SD?
If your running boost on a 5.7 with 42# injectors with a stock pump i would imagine your injector duty cycle is pretty damn high... Do you have a fuel pressure gauge or a wideband? Also there is no FPR on a 04+ truck, unless you switched to a return style fuel system...
Old 10-09-2009, 11:20 AM
charcold-bowtie's Avatar
my injectors are maxed at 9 psi on my 4.8. They are 42lbers
Quick Reply: New MSC front mount turbo almost done!
