New Radix Project(8rib conversion)........w/pics :)
Old 03-25-2006, 08:06 AM
  #31
what a rush!
moregrip's Avatar
Originally Posted by MNC5
A plastic retainer in the snout kept breaking on mine at those speeds. They wouldn't last a week in mine, good luck
If that ends up being the case for me as well then I will back it down. The problem you mention is the first I've heard of it, care to expound?
Originally Posted by JimS
Very cool trick parts and good ideas Grippy. Are these one-off parts or are they available? They gotta look great with the Metco's. What belt will you use? Will this 8 rib belt make the system increase the resistance to belt slippage and consequently make it even more important to pin the pulley?
Zippy & I will be putting either a 2.8 or 3.0 pulley on my Radix and then doing the Alky Control meth kit to keep the temps down.
Thank you, I will be pinning the crank using Magnuson's kit. After you have the Meth dailed in, I'll need some info as far as usage. Such as how many gallons per say, you go through in X amount of time. Trying to ballpark it.
Old 03-25-2006, 08:11 AM
  #32
what a rush!
moregrip's Avatar
Originally Posted by TG02Z71
What's the backside of that pulley look like?
Is it a two peice screwed together? The reason I ask is all the screws in the face.
Looks like more power for you, which will mean you will need even....... MoreGrip!! Haha get it...hahaha.
I'll take some shots of the backside for you this weekend. Yes the aluminum damper bolts to a steel sleeve. In the future, crank damper removal will simply be unscrewing a few bolts. The same goes for the power steering pulley.
Originally Posted by Richard@WCCH
Looks great Grippy! The parts pile just keeps growing Your garage must look like a candy store.
MJ said it earlier, your taking the Radix to the limit and beyond. Keep up the great work.
Richard
Thanks Richard then it's a good thing I keep my shelves stocked
Old 03-25-2006, 08:15 AM
  #33
Fogle07's Avatar
very nice grippy. when do you plan on the install?
Old 03-25-2006, 08:16 AM
  #34
what a rush!
moregrip's Avatar
Originally Posted by BLOWN 364
Your the man
Now i will be able to spin my blower up like the lightnings
Thanks brother when I trial fit everything and ensure its all good to go you'll be the first to know
thanks man, as soon as the exhaust is wrapped up the install marathon starts
Old 03-25-2006, 08:34 AM
  #35
FormerVendor
leftcoast32's Avatar
That is a great looking setup and should help with belt slipage! We really need to get together so you can show me some of these great projects you have been doing. Have a great day!
Old 03-25-2006, 09:18 AM
  #36
what a rush!
moregrip's Avatar
Thanks Joe. Next week right?
Old 03-25-2006, 10:02 AM
  #37
How's the clearance to the waterpump pulley?I know it would be really tight with a Evans waterpump.
Old 03-25-2006, 10:18 AM
  #38
Kano's Avatar
I notice its keyed
I havent really kept up with how much problem that is
for the FI guys as far as the pulley slipping,
but makes pretty good sense,
esp with the larger pulley
looks good
Old 03-25-2006, 10:52 AM
  #39
what a rush!
moregrip's Avatar
good question.
it will clear the stock waterpump, but just barely, and something I am not comfortanle with, so I will be uprading to the full Evans system. The Evans water pump would equal the same clearance as the stock arrangement. 5 3/4" is the stock WP pulley size, 5 1/4" is the Evans WP pulley size. According to Evans, with the 8" crank pulley and their 5 1/4" water pump I will be right in the sweet spot of their specification for street driven vehicles, about 17% overdriven.
Old 03-25-2006, 10:54 AM
  #40
what a rush!
moregrip's Avatar
Originally Posted by Kano
I notice its keyed
looks good
Thanks Kano
The keyed pulley is if I decide to go to an aftermarket crank in the future. I will be using the Magnuson pinning kit on my current setup.
Quick Reply: New Radix Project(8rib conversion)........w/pics :)
