New turbo manifold in Trick kits.
#21
#22
Truck Sponsor
No it is not a direct swap for the older Gen 2 or 1 stuff.
Turbo is almost in the exact same spot. I tried to tilt it over a little more away from the oil filler area.
The crossover flange rotation and angle ended up off.
#23
Truck Sponsor
Another thing we started to add to ever kit is a drill and tap for the oil pan drain fitting.
I had several customers that could not find or did not own them. So now they are included as well..
#25
That's a nice looking piece! Just wondering though... How well is the WG gonna clear the oil drain and compressor housing? Do you have a pic of it mocked up on a motor with a turbo on it?
#26
Truck Sponsor
Yea it's needed.
Thanks Kyle,
Oil line clears.
Compressor cover clears.
The gate has a slight tilt hard to see in the pic.
It was added as a what if. . Seeing how these engine are put into so many different applications now.
Will post up more pics later.
Oil line clears.
#29
Truck Sponsor
1000.00 includes gaskets, studs, nuts, etc.
Do you need a gate block off cover?
Yes. The fire wall lip will need some more lovin then before if using an older dp.
All dps that leave now will be a tad shorter at the vband flange area.
