New turbo manifold in Trick kits.
#38
Truck Sponsor
Normally 1600.00.
But I can do a set for 1500.00 and free freight. .
These would be our stage 4 pipes.
3" down pipe fits the most turbos that use a 3" vband.
The gate hole in the manifold is 40mm.
The only reason to run a 60 gate is large cubes and low boost.
What turbo are you using?
#39
Just in the planning stages at the moment. Ive been told an S475 would fit the bill for what Im wanting to do and itll be on a heads and cam L76. I tow heavy from time to time so I want a gate big enough to stay down around 5#s. Do you have one piece DPs in 3.5"? I see on your site that the stage 5 has a two piece 3.5" but didnt know if that pic is out of date since you have so many new goodies coming out.
#40
Truck Sponsor
The 3.5" was a welded several sections. Then cut into 2 pc. So it's easier to install.
The new 3.5" dp. Will bearded bent 2 pc design. Noire cutting and welding pre bends.
The 3.5" set does cost more. Not solid on the final price yet.
The lower psi won't be a problem.
You max setting will still get set by the gates spring.
