Newbe with a Procharged Silverado and some questions
Heres a pic with the pcm moved out of the way.
You can tell I wasnt going under the frame with the plumbing,but it shows how much room there is without the pcm there! This pic was taken while I was mocking it up for a front mount design instead of underneath!
I will take a look at moving it. Thanks for the advice. You know Procharger should add something to their manuals about the 4x4 models requiring this. Hopefully i can get that done this weekend. I have scheduled a tune for wednesday at Procharger in KC. I will post some numbers and pics from the day. Later.
So where is everyone moving their pcms to? Does it have to come out of the housing like the earlier pic w/ the race valve? Also, any tips or tricks you've found out during the process. Thanks.
I just modified the ecu housing, but kept it so the ecu still clips in and out as needed. I made a little L-shaped bracket that attaches to the housing and gets bolted to the truck, using the same bolt that holds the bar running across the top of the battery. I basicly just moved it up!
5.3lSilverado
25
08-29-2016 12:48 AM
D1SCSS
01-25-2016 10:14 PM
mzoomora
01-03-2016 07:06 AM
