Nitrous and turbo
Old 10-17-2012 | 04:52 PM
turbo6.2's Avatar
Banned
Default Nitrous and turbo
Ok guys how could I hook up nitrous to stall my turbo up some I here of ppl doing it so I think I migh give it a wack currant set up is built 6.2 magnum 72mm I have meth as well I also have 4wd but I wanna launch in 2wd on my slick I'm just wanting to know how to and where to put the nozzle to spray it
Old 10-17-2012 | 05:28 PM
JoeyGC5's Avatar
That turbo should be spooling very quickly on the 6.2L. You can add a wet or dry nozzle 6" or so before the throttle body and adjust timing and fuel according to what type and hp size kit you want to use.
Old 10-17-2012 | 05:46 PM
turbo6.2's Avatar
Banned
I was thinking of buying this plate system or would u stay whith a shark nozzle
Old 10-17-2012 | 05:55 PM
nonnieselman's Avatar
Plate over a nozzle anyday.
Like mentioned, that lil 72 should spool fast on the 6.2.
How much boost you plannin on runnin?
I used a 50 shot on my old STS setup and it helped a bunch.
6psi
13.2@104
6psi + 50 shot
12.5@111
Old 10-17-2012 | 06:16 PM
turbo6.2's Avatar
Banned
I ran a 12.50 at 110 in 75 degree weather I'm about 11lbs of boost whith vaul float I'm planning on cranking it up to 15 and a 50 shot I'm wanting to see 11.70s my build is a custom cam for turbo from eps and 3200 stall circle d but my damn breaks is messing up like hard as a rock sometimes when u try to stall it up but I'm at 9.5.1 compression so I believe I can run alot more boost
Old 10-17-2012 | 08:07 PM
Wait you think the valves are floating?
What springs?
Old 10-17-2012 | 08:08 PM
What springs?
Old 10-17-2012 | 09:11 PM
turbo6.2's Avatar
Banned
PAC double springs that's what my tuner said I have float but I have .650 life springs and my cam is onley 600 life so they want me to get tietium vaul springs man I'm all new to this. And probley need loads of help
southernsmoker
08-31-2015 03:09 PM
LCHEE
08-30-2015 03:53 PM
mz00516
08-23-2015 12:19 PM
custm2500
08-22-2015 11:46 PM
Quick Reply: Nitrous and turbo
