Not enough injector for the ProCharger...
Adkoonerstrator
Originally Posted by PappyDan
a after market regulator and a good set of 42 lbs injectors can make a world of difference.
so far every book I have read on moding our motors with a turbo or a supercharger.
2 things remained constant a regulator to set the fuel pressure to 80 psi and a set of 42 lbs injectors.
should be getting a Walbro 340 high pressure installed this weekend...hope that cures it...plan on running it alone w/o the ProCharger supplied in-line...
I have had one of them fail already and I just have a feeling that this one is contributing to this issue, as well as the stock in-tank...
Adkoonerstrator
I have used the in lines in the past and if they are going bad they are a MAJOR restriction.
A good walboro in tank will take you a lot higher than you're at now, so that will be nice.
last time I checked fp, it was 50#'s @ idle...haven't checked it @ wot on current set-up...what's ironic is that the rpm level I was maxxing old injectors at is about the same level I am now starting to get kr that rises quickly...
