Not impressed by the "Hype"
#41
Im running that combination now at ~11 psi not 9psi. No knock. Dont plan on a dragster and that isnt what this is about. Just wanting to know why I didnt get the results that most ppl have posted for the mods I added? Stock run was a 16.9. "1st Run" Radix, e-fans and 55hp wet shot @ 14.2. "2nd Run" New Mods hoping for a 12.9 is that impossible?
#43
If you look at "Last Call" post on page 4. His trq #'s drop hard too..... Tuner told me it was pulling 1* to 2* at the top.....12* down low and 10* up top. He says a GT2-3 would move the peak over higher in the rpm's but it will eventually fall off. Does a double heat exchanger really work? I was actually looking into the kiler chiller intercooler colant chiller.... just a thought.
#44
Pulling timing is ok when the air is getting hot, it should do that. What I see is more of an efficiency issue. The Radix MP112 didn't always make a big number with big boost. High boost levels with that will make big heat not even concerning how fast you spin it. With that pulley size you're ok spinning it that fast without much issue, but you need to get the boost level down some. Put a cam in it. You'll make a much better power number with more cam in there and with a lower boost number pulling the blower back near it's higher efficiency range. Also, what's with the timing being that low? Unless you are also expecting to spray a 75 shot or something with it, put some timing to it. Cam it with more timing and you'll see the numbers you are looking for. I think you more than over estimated on the 90mm throttle body numbers though. You need to move alot more air before it's even close to that number.
#45
Moderately Differentiated
Here is a radix 2000 silverado 5.3 from maggie's site.
#46
What are you guys wanting from me that will help you diagnose my truck? The Diablo has a scan/record tool that I can bring up on my labtop? I cant explain the timing.. I guess he feels safe with it that low that he wont make my truck explode. I am running a 55 wet shot but that wasnt recorded on the dyno since it wasnt working at the time. Will the nitrous increase my boost also?
#47
Don't see where you changed valvesprings.
#48
It is possible that the blower was just hot on the dyno. I've seen IAT tables that were set up to pull zero timing as they got hot. Other than track use that can be a ticking time bomb. A dyno run rarely takes long enough to cause problems with the IAT's and if the blower is cool enough before the runs are made it should be fine. Most tuning I run into for Radix's just don't have nearly enough commanded timing to start with. We haven't seen his tuning though and there is likely issue's there. The Magnacharger dyno sheets I don't use, their dyno has been called optimistic over the years because most people can never duplicate their numbers even with bolt on/plug and play kits. Not insulting them, but many have pointed that out. How many stock 5.3L's put down 265 and how many bolt on the blower and go 5.3L's put down 395??? As for his hp falling off at 4k, are we looking at the same dyno run? It's not a smooth run, but it pulls just fine to 5500 or so just as a stock cam does on higher boost. At that boost level the waves as the rpm comes up is likely valve float.
#50
I would do a cam and valvesprings with hardened pushrods and then a retune. You'll see a healthy increase. Take a look at trever1t's webpage.
