O2 sensor location in front mount turbo setup, opinions
Originally Posted by WJ MARK
It won't read the 2 banks individually. you want to be able to see what 1,3,5,7 are doing on one side and 2,4,6,8 on the other side.
Originally Posted by 350SS
What will happen then?
My guess is that the nb in the downpipe is so much further away from the exhaust ports compared to the stock location, when the pcm makes adjustments during closed loop operation it is doing so based on "old" information. Meaning that the exhaust hasn't travelled down the pipe to the nb since the ecm made it's last a/f adjustment. So it would continuously "overshoot" the correct afr. If you can adjust how fast the pcm makes closed loop adjustments, this might correct the situation. This is just a guess based off of my limited knowledge of closed loop operation.
That sounds reasonable. The l-trims were tracking together then went extremly lean or rich with no concistancy, and a large offset. Others as well as myself have one in the crossover and one in the down pipe with no problems.
LS1Tech Sponsor
Since the backpressure of the turbo is present on the 02's they are not as accurate anymore. Put a wideband in there and you'll see the difference.
Design of the system determines where the 02's go. If it is a log you want 1 02 on the driver side and the other in the downpipe.You do not want the 2nd 02 in the log. If your running closed loop it will screw with the tuning.
If you have your own software then go 2bar SD and shut the 02's off.This is how my truck is done and runs perfect.No worries of 02 problems.
Also,my wideband is in the downpipe about 12" from the turbo.
D1SCSS
01-25-2016 10:14 PM
oharajo
07-18-2015 09:24 PM
