Oil in compressor side of turbo
I took my charge pipes apart the other day and noticed oil was passing through the compressor seals and blowing into the pipes. I have a -4an feed line with -10an return line, and had a .090 restrictor in it. So I swapped to a .075 and it improved but still passed some, and now I'm at a .064 and still having some pass through. My return line flattens out somewhat where it loops around in front of the crank pulley, but I dont think its enough to cause a problem. Anybody had similar issues? I know most of the time the issue comes crommthe other side of the turbo. I can go smaller on the restrictor, but im worried about damaging the turbo. My truck usually has around 60psi oil pressure at cruise.
The turbo has been on since December, but I havent beat on it at all really. Only a few dyno passes, 99% of its life it has been cruising under vacuum due to a stock tranny. I bought a 45* fitting to go on the bottomof the turbo that should let me keep my drain a little more vertical so hopefully that will fix it. I dont want to go any smaller on the restrictor if I can keep from it
TX Tahoe Z71
09-01-2015 09:11 PM
blowing, coming, compresor, compresser, compressor, ctd, ford, ls1, oil, performance, restrictor, side, truck, trucks, turbo
