oil feed line?
My kit came with a plate the bolts to the side of where the oil filter is on the engine... the plate was pre threaded for a fitting to connect the line to.
If you look above the oil filter, theres a oil port boss. its got 2 bolts holding it on.
Take that off and drill/tap it for 1/8" NPT and put a fitting in there to adapt it to -4AN. Vola theres your oil feed line.
No restrictor here.
No restrictor here.
I have mine tapped like mentioned above no restrictor -4an feed line. I also have a plate that u can bolt between with a fitting on it. I can upload a pic for u if interested. I do have it for sale
Mine is a little different since it is in a swap vehicle. I used the oil pressure gage port on top rear of the engine. I had already tapped the one above the oil filter for my gage. 4an no restrictor either.
