Oil feed restrictor
I haven't done this yet, but need to. Alot of guys are either running nitrous jets or the function7 setup. You've probably already seen this, but just in case you haven't:
https://ls1tech.com/forums/showthread.php?t=569238
Originally Posted by thunder550
Where did you put it?
Originally Posted by kbracing96
I still have the check valve from the sts on the turbo, so I took a brass 1/8 NPT close nipple and filled it about 1/3 full of soder and drilled it out with a .075 drill bit. Then I put it between the check valve and the -4 inlet fitting on the turbo, using a 1/8 NPT coupler too. I would have used a N02 jet, but this was faster as I don't have a place around here to buy them.
Just braze the brass fitting closed and drill a smaller hole.
LS1Tech Sponsor
We use Nitrous jets. Choosing the right size can take time.The correct way is to put a oil pressure gauge at the turbo and get the recommended pressure which is ussually 30-35psi. I just go by the oil smoke out the exhaust. Ussually end up with a .051 to .072 depending on oil pressure at the engine.
