Oil feed restrictor
#23
I've been running a Precision turbo for almost three years now with no problems. Supply line is a -4, then welded(closed) the fitting that screws into the turbo and drilled a 1/16 hole. This is my only experiance with turbos, but a friend with lots of experiance does this and highly recomends this.
#24
Originally Posted by JOHN1L40
Would oil getting into my intake under long boost, towing, be helped with an oil restrictor? I do not get smoke just oil in the intake. I have my turbo upgraded and rebuilt and it still sucks oil. I have the biggest air filter on the intake directly mounted to the turbo. I am going with a larger Wastegate to make it easier to blead off pressure while towing under lower boost. I dont know if this has anything to do wioth the intake oil but I hope it helps.
#25
TOTM: November '07
Can anone comment on this? I have worked with STS and have tried everything. Parking angles, new check valves, air filters, high speed return pump etc. still gets a lot of oil in the intake.
So my oil system consists of -4 line back to the turbo, with a restrictor about 10" before the turbo. The oulet of the turbo runs straight to my pump- the nipple of the pump is below the level of the turbo drain.
You might try running power straight to the pump to see if it is an oil return problem- I know that even with my restrictor there is a good bit of oil flowing even at idle.
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
09-25-2015 12:36 PM
075, 4an, feed, line, ls1, needed, oil, on3, performace, performance, recommended, required, restrictor, size, sts, turbo
