Oil feed restrictors
Old 12-24-2007 | 01:39 PM
Derek @ EDO's Avatar
FormerVendor
Default Oil feed restrictors
Question!
What are you guys using?
-3AN or -4AN feed lines
Are you using any type of restrictor to prevent smoking?
Im using a T-76 F1-Trim
Im now ordering all the oiling parts for the build
Thanks,
Derek
Old 12-24-2007 | 03:35 PM
FormerVendor
Ahhh, i just ordered the Function 7 -4AN regulated inlet fitting.
Old 12-24-2007 | 03:43 PM
dan96z71's Avatar
I want to say my Trick kit had the -3AN
Old 12-24-2007 | 03:57 PM
Bill Reid's Avatar
-3 AN with no restrictor
Bill
Old 12-24-2007 | 04:21 PM
FormerVendor
Well, .125 is the ID of -3 AN line so i will just drill my "restrictor" with a 1/8 bit.
Should work fine!
Thanks guys,
Anymore opinions on this subject?
Old 12-24-2007 | 05:33 PM
Bill Reid's Avatar
Should work fine!
Thanks guys,
... thats what I did with my Function 7 -3AN adaptor
Bill
Old 12-24-2007 | 05:43 PM
FormerVendor
Sweet! The reason why i purchased -4an was incase i drilled a little too big. If i drill too big ill just drill the hole 1/4" and use various size NX jets. I Dont think you can use NX jets with -3AN.
Old 12-24-2007 | 06:22 PM
thunder550's Avatar
High on diesel fumes
I'm running a .053 nitrous jet for a restrictor. I think my feed line is -4.
Old 12-24-2007 | 07:26 PM
FormerVendor
Really!
3/64 .0469
1/16 .0625
The regulator on my Function7 flange is basically a a 1/16 inch hole which can be drilled out to increase oil flow.
Hmmm, currently your running smaller than 1/16"
Whats your oil pressure like?
Im installing a ported Melling Oil Pump on the 370 im building so i may have to go with a small hole as well.
Thanks,
Derek
Old 12-24-2007 | 07:31 PM
OLD BULL's Avatar
Should work fine!
Thanks guys,
I'v been running a -4 with a 1/16 hole (welded and drilled in the npt/an fitting on the turbo) for three years now with no problems. When I was told to use 1/16 drill bit I thought it had to be too small, but it works great not one bit of smoke.
