Oil feed restrictors
Old 12-24-2007 | 07:37 PM
Derek @ EDO's Avatar
FormerVendor
Originally Posted by OLD BULL
I'v been running a -4 with a 1/16 hole (welded and drilled in the npt/an fitting on the turbo) for three years now with no problems. When I was told to use 1/16 drill bit I thought it had to be too small, but it works great not one bit of smoke.
So from gathering this info looks as if ill just throw her on with the standard 1/16 hole.
I know Oil pressure plays a big part in the sizing since a higher pressure will feed more oil through the hole.
Whats your oil pressure like?
Thank you for the info
Old 12-24-2007 | 09:12 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by Derek @ EDO
Really!
3/64 .0469
1/16 .0625
The regulator on my Function7 flange is basically a a 1/16 inch hole which can be drilled out to increase oil flow.
Hmmm, currently your running smaller than 1/16"
Im installing a ported Melling Oil Pump on the 370 im building so i may have to go with a small hole as well.
Thanks,
Derek
I'm at 55 psi on a cold start, about 45-50 with a warm engine at idle. 65-70 at higher RPMs. I'm running straight 40 weight oil.
Old 12-24-2007 | 11:12 PM
fullthrottledan's Avatar
im running a -4an with i think a .060 jet. (cant remember if it was a .060 or a .058) no smoke. oil pressure is 65-70cold and 50-55 warm
cheyenne383
11-13-2015 10:24 AM
lukn4trbl355
10-22-2015 12:19 AM
GMCtrk
10-20-2015 07:17 AM
sTNT971
09-26-2015 05:22 PM
lxcoupe
09-25-2015 01:36 PM
