Oil Feed and Return
Oil Feed and Return
I have read a couple of threads of people using an adapter(one that a member here makes) where the oil filter is or taping the existing block off plate. I have also seen adapters that sandwich in between the block and the plate for those hat have the optional oil cooler.
My question is are both ports coming off the block pressurized?
My thoughts were to use the two lines that normally go to the oil cooler. One or the oil feed and the other for the drain. That is if they are not both pressurized.
If I can use the high pressure side to feed the turbo then I can use the other side to return the oil back to the pan without having to tap the oil pan.
I have a gauge for that
I think there is something going on in the block to the cooler since so many guys use that block off plate for their turbo feed (me included), the pressure at the plate would have to be engine pressure because if it wasnt and only one side was pressurized the turbo would never get oil...
I just got off the phone with someone who sells adapters and it would not work. Yes, one side has pressure and the other does not but the one that does have pressure needs to pressurize the other side in order to feed the motor with oil.
So if I used the pressurized side to feed oil to the turbo then tried to use the other side for a return it would not have enough oil pressure to feed the engine. I do have an oil pump since I have a low mount turbo but I don't think it could make enough pressure to feed the motor.
Pretty much every turbo kit (front mounted) runs a 1/2" or 5/8" oil drain that is gravity fed back to the pan. The oil pressure is so low on he drain side of a turbo that just an minor uphill restriction in the drain line can cause you to blow oil past your seals. Tapping into the drain side of the cooler would just fill your turbo drain with oil and blow out your turbo's seals.
Keep it simple and just tap into the oil pan for the drain. I tapped the front of my pan below the harmonic balancer twice and it still only took about 30 minutes. If you use a 3/8npt tap after the corresponding drill bit, you can just use a short piece of hardware store 3/8" brass pipe that will hold a 5/8" drain hose with a clamp.
Rick
2nd that. You be running your turbo with 0 psi until the motor warmed up.
Rick
Rick
If they did not have pressure until up to temp then Sinr98's setup would starve his turbo every cold start.
