oil less turbo
Old 02-20-2012 | 03:55 PM
evand's Avatar
Default oil less turbo
I was wondering how this would work on a lq9 in a silverado ecsb running it as a front mount
Turbochargers Comp Turbo - CT4 5762 Standard
Old 02-20-2012 | 08:56 PM
kbracing96's Avatar
First, its WAY to small for a 6L. You would need 2 of them. Its only a 57mm turbo. A 6L needs a 72-76mm turbo to be beneficent. Second, have you prices how much they want for those oil less turbos??? $$$ They are cool, but they need to cut the cost about in half if you ask me.
Old 02-20-2012 | 10:12 PM
evand's Avatar
so the bigger turbo like this
Turbochargers Comp Turbo - CT4 6765 Standard
Old 02-20-2012 | 10:15 PM
2000chevysilverado's Avatar
What's the pricing on these to late to call
Old 02-20-2012 | 11:54 PM
Suburbazine's Avatar
About 2.5 grand for the turbo all said and done. In that vicinity at least.
And the bigger turbo posted is still not 72+mm.
Old 02-21-2012 | 10:13 AM
kbracing96's Avatar
You would need something like this,
Turbochargers Comp Turbo - CT43-7479 Billet
Its a 74mm compressor and a 79mm turbine. Don't pay attention to their HP ratings, those are flywheel rating at about 30-35psi which is more then you can run. These motors need high cfm of air flow at lower pressure because of there large displacement and high flowing factory heads.
Old 02-21-2012 | 12:07 PM
Alpinestar's Avatar
Unleashed Performance - 810RWHP, Stock Engine, Oil-less Rear Mount, and E85 - LS1TECH
Here's a build with a comp turbo on it... but I would just run oil lines/tap the oil pan since you are wanting a front mount. It's not that hard and you will save yourself a lot of coin
Old 02-21-2012 | 12:29 PM
ak2007r6's Avatar
Description:
CT4 Turbocharger with a CT67 Compressor wheel, HE65 Turbine wheel. Perfect for 1.5 to 6.0 liter engines with power levels up to 775 HP.
HAHA holy **** thats quite the spread on displacement....
Old 02-21-2012 | 02:14 PM
evand's Avatar
I see the hp and displacement on the chart threw me way off.
Old 02-21-2012 | 05:54 PM
M&M Turbochargers's Avatar
on a 6.0l you prob want about a 76-80mm compressor
