oil pressure too high???
I took my rear mount off and front mounted it and now when I get on it it smokes like CRAZY. So I put a nos jet in there at about .050 (3/64) and it helped a little but its still way too bad. When I had it on the rear it didn't smoke at all. I would put a smaller jet in there but I don't want to burn up the turbo. What do you guys think I should do? (I've already spent alot of time in the search section)
Thanks
Thanks
oil presure is at around 40 when warm and idleing but thats not the problem problem is when I get on it it leaves a big cloud of smoke behind me. and I know its not the turbo because it didn't do this before I swithched it to the front.
It's blue smoke and it only happens when I get on it and the oil pressure increases. I took the one way valve off the sts setup when I switched so I think im gonna put that back on and see what happens.
