Oil restrictors....
Old 12-13-2007 | 04:06 PM
Big Thumper's Avatar
Cute hat.
Old 12-13-2007 | 04:10 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by Big Thumper
Cute butt.
Excuse me?
Old 12-13-2007 | 06:32 PM
TG02Z71's Avatar
Do you have a ported or modified oil pump making more pressure than a stocker, or more flow? Just curious.
So the jet your using has a restrictor has a .05" diameter orifice or is it a #50 jet?
Sorry for the questions, trying to pick up some knowledge here.
Last edited by thunder550; 12-13-2007 at 08:00 PM. Reason: clicked edit instead of quote, oops!
Old 12-13-2007 | 08:00 PM
thunder550's Avatar
Pump is a Melling stock replacement. Should be the same specs as a stock one.
The current N2O jet is a .093", and the one I just got today (but have not installed yet) is a .052".
Old 12-13-2007 | 11:38 PM
SpoolinChevy's Avatar
I have the same problem, but i was told restrictors weren't the best thing. I'm about to send mine in to see if the seals are bad, so maybe that'll do the trick.
Old 01-16-2008 | 03:35 PM
TURBHOE's Avatar
what size lines are you all useing?
Old 01-16-2008 | 03:54 PM
Derek @ EDO's Avatar
FormerVendor
im going to use a -4, some use -3
I don't think you can use restrictors (NX jets) with a -3 line though.
So in other words if you blow oil past the seal with a -3 line your pretty much SOL unless you have a function7 -3 restrictor inlet flange.
lukn4trbl355
10-22-2015 12:19 AM
sTNT971
09-26-2015 05:22 PM
lxcoupe
09-25-2015 01:36 PM
69z-28
09-21-2015 08:31 AM
Velocity1
09-16-2015 12:29 AM
