oil return/drain line
Old 04-12-2009, 09:13 PM
  #21
silveradol33's Avatar
Originally Posted by charcold-bowtie
hey random I think it come straight outta the turbo. No 90 needed IIRC
Correct
Mark, for the turbo you are gonna want a straight fitting then down and prolly a 90 at the pan like you already said.
Old 04-13-2009, 12:22 AM
  #22
Hunt&Fisherator
silver-mod-o's Avatar
Randoms doing a rear mount I believe. I need to get ahold of one of WJ Mark's plates. My feed has always leaked there.
Old 04-13-2009, 06:57 AM
  #23
Ahhhh, somthing I did not know, lol. Mark knows his ****, I shouldnt have doubted him
Old 04-13-2009, 11:07 AM
  #24
RandomHero's Avatar
I'm actually doing a variation of Kyle's Front mount kit(only cheaper so I can afford it).
I'm using his hot parts and intercooler setup
T61 Precision turbo(VanillaGorilla's)
Tial 38mm Wastegate
Tial 50mm BOV
This is my first time going to forced induction fellas so the only knowledge I have is from guys like you who have already done it. Thanks for the tip though.
Thanks, but for the most part I'm full of ****,LOL.
Old 04-13-2009, 01:57 PM
  #25
11 Second Club
Phantom's Avatar
How do you guys feel about 45* fittings?
Old 04-13-2009, 09:15 PM
  #26
I have one on mine. They are just fine.
Old 04-15-2009, 07:35 AM
  #27
Hunt&Fisherator
Tial 38mm Wastegate
Tial 50mm BOV
looks like youre well on your way as well... but for some reason I thought you were putting an STS together...
Dan, 45's are fine if you use them right... mainly avoid sharp turns let it free flow back to the pan.
Old 06-05-2009, 05:18 PM
  #28
RandomHero's Avatar
Sorry to bump this back up, but I think I may finish up my turbo build.
I have a pretty good idea what all I need, but I want to make sure I'm not forgetting anything. If any of you who has done this if you wouldn't mind looking over my parts list I'd sure appreciate it. I'd just assume order all this stuff tonight.
Feed:
5' -4an braided line
(2)-4an to 1/8npt straight adapter
Turbo feed adapter with gasket
WJ Mark Oil cooler adapter plate
Drain
-10 push lock hose
(2) -10an straight push lock adapters
(1) straight -10an to 1/2 npt adapter
(1) 90* -10an to 1/2 npt adapter
Would you guys recommend doing a 45* instead of the 90* out of the oil pan? I know you guys said the fewer bends the better, but I noticed Charcold-Bowtie's oil pan adapter is a 90* bend
Any extra things I should get while I'm at it?
Thanks fellas
Old 06-05-2009, 05:29 PM
  #29
11 Second Club
Phantom's Avatar
Mark try to stay away from the 90. I got a -10to npt 45* to go in the pan then to straight -10 fittings
Old 06-06-2009, 02:01 AM
  #30
Hunt&Fisherator
I'll snap a pic of my drain/feed all installed tomorrow for you... I got 3' of -10 hose and it was pretty long... I'd probably go with 2 or 2.5ft next time around.... I've got a 45* swivel on the pan and a straight fitting on the turbo for drain... the feed is a WJ MARK plate, a 1/8NPT-4AN 90* adapter fitting... and I've got a 90* -4 swivel on top of the turbo.... Ive got a manual oil pressure guage up there too, but I'm paranoid LOL
where you put the hole in relation to the low oil level sensor and starter is the biggest issue and usually dictates if you run a 45 or a 90.... mine BARELY touches the starter case but its not enough to hurt, I got away with a 45...
GXPJAY
02-13-2022 08:15 AM
chopperloco
07-10-2016 10:45 PM
jroctpb
08-11-2015 03:52 PM
Mzay
07-06-2015 11:03 PM
Quick Reply: oil return/drain line
