P0068 after TVS install
Old 03-06-2010 | 08:30 PM
smokeshow's Avatar
Mod with training wheels
Default P0068 after TVS install
Just finished installing the TVS1900, followed the directions exactly. Engine will usually start and idle just fine, sometimes it has a bit of an issue...I figured it was leftover air in the fuel rails. I can accelerate, but under WOT it pops the code and the engine reports "engine power is reduced". Code that pops up is P0068, MAP/MAF - Throttle Position Correlation. Anyone seen this before? It's barely drivable with this.
Old 03-06-2010 | 09:11 PM
hellbents10's Avatar
LS1Tech Sponsor
Need to have that adjusted in the tune. Have you have it tuned yet???
Old 03-06-2010 | 09:33 PM
Toomnymods's Avatar
sounds like you need a upgraded maf? same thing my truck did with the stock maf after i installed my turbocharger.. i was pegging the maf and soon as it hit 400gms of air per second it would kill the engine and it would die/sputter
a upgraded maf should be able to read up to 750-800 gms of air a second but will definatly have to be tuned for..
Old 03-06-2010 | 09:49 PM
no need for upgrade MAF, adjust the tune
Old 03-06-2010 | 11:21 PM
smokeshow's Avatar
I figured it out. The tune is set for a 1bar map, while I had a 2bar installed. Swapped back to the old one for the time being.
Old 03-06-2010 | 11:50 PM
quez82's Avatar
How's it running now
Old 03-06-2010 | 11:57 PM
smokeshow's Avatar
it screams
Old 03-07-2010 | 12:04 AM
quez82's Avatar
I'd love to see some numbers haha
Old 03-07-2010 | 12:45 AM
bud8fan's Avatar
Originally Posted by anasasisxenophontis
it screams
nice...that 60e isnt going to like you very much...
Old 03-07-2010 | 08:15 AM
06vortecmaxxx's Avatar
Which map sensor did you end up using? The one they suggest?
