P1 smallest pulley with no belt slip?
I have finally decided to install my P1 procarger kit since I sold my magnacharger and I have a few belt slip questions on the P1. My stock pulley size is a 4.0 and I would like to know what is the smallest pulley I can reduce down to on the stock tension setup without any belt slip?
Also, are their tensioner mods on the P1 setups to reduce belt slip?
Baltimore Whore
If you have the later/revised kit, that has the idlers relocated then you can prob get away with a 3.6-3.5.. If you have the old style you will want to relocate the idlers around to get maximum belt wrap, still use that size.. That is prob the most your going to get out of the 6 rib pulley..
