Peak and hold injector driver
I installed an Acceleronics Versafueler (peak and hold low/high z injector driver) and big 72# (86.6# at 58psi) low impedance Delphi injectors this weekend.
I gotta say that if you are running big injectors, you want one of these. You can run it with high or low impedance injectors and it makes a huge difference in idle. I ran it with both the 60# high z and the new injectors -- both sets idle well, and the 60#ers idle better than they did without it.
Overall, its a nice kit -- great instructions, nice compact design. The install was simple (clip 8 wires -- the injector ground wires -- and splice in the leads for the versafueler, attach the ground and 12v cranking leads, and mount the kit... easy peasy).
So far, I love the delphi injectors with this kit. The truck idles better than the motos did -- almost like my wifes stock av... All this with stock injector offset tables.
ARC
57
02-21-2022 10:54 AM
GXPJAY
02-13-2022 08:15 AM
05GMC4.8
08-07-2015 09:55 PM
