The phelomic spacer has been out awhile now is it worth putting it on the 2300 tvs
Old 09-25-2013, 07:44 PM
silverstreak07's Avatar
Thanks..yes stock tranny and converter..I didnt really watch my timing at the end i know im running 20 degrees of timing. WHEN WE TUNED IT IT WASNT SENSING SPARK KNOCK THERE but maybe when it gets warmer it pulls a few gegrees..Now if u have timing set higher will it pull MORE timing if it senses spark knock,OR IS IT BETTER TO BE DEGREE OR TWO LOWER..IM
still new to this so i like asking you guys with experience.thanks
Old 09-25-2013, 08:49 PM
Vortec350ss's Avatar
On the dyno you generally don't have it pinned from a stop past 110 MPH. They will be shorter bursts which wouldn't hear up the blower as much
Old 09-25-2013, 08:50 PM
11 sec. Truck Mod
TIM Z's Avatar
You better leave it where it's at , till you can upgrade the trans / converter.
Then I would bump her up to 12 psi , along with said trans mods she will be an animal .
In my opinion your not at a point where you need a spacer yet , I would do that down the road when/--after you up the boost , or if your bored this winter .
Old 09-30-2013, 10:26 PM
terravast4's Avatar
how much is the spacer?
Old 09-30-2013, 10:56 PM
TheBurlyMan's Avatar
Its $500 damn dollars plus shipping...if it was a $100 less I would already have one. Its a great product and I want one but can't do the $500
Old 10-01-2013, 04:08 AM
03sierraslt's Avatar
I don't think the gains are as relevant till you turn up the boost. Granted my spacer is only 5/8"
Old 10-01-2013, 09:01 PM
If i put the spacer on will i gain or loose boost....WELL guys what should i turn it up too 12psi...will i notice from 10psi to 12psi..
Old 10-01-2013, 09:25 PM
I lost about .5lb with mine but I also ported the lower manifold at the same time. Spacer or not you will notice from 10-12 psi. Is your setup overdriven or not? What pulley are you running? Just trying to get a idea of how much air you are actually moving. Boost level doesnt really say much.
Old 10-01-2013, 10:09 PM
Ph.D. in HUBRIS
custm2500's Avatar
Wouldn't meth or a small shot of nitrous make much more sense for $500!?! I am assuming it insulates and lengthens the runners into the head so should help with a bit of top end power?
Old 10-01-2013, 10:14 PM
1st off Phenolic is expensive.
2nd the CNC time is also expensive.
Yes more boost or some nitrous would do the same, however by optimizing the setup you are not increasing the stress on the motor. I did mine because I was able to obtain phenolic on my own and wanted to more or less experiment for my own knowledge.
Quick Reply: The phelomic spacer has been out awhile now is it worth putting it on the 2300 tvs
