Physical Range of 90mm LS2 vs 78mm TB
Old 11-21-2006, 10:46 PM
  #61
2004SSS's Avatar
nice work man, you deserve a pat on the back!
Old 11-21-2006, 11:03 PM
  #62
BigTex's Avatar
I think that is much improved. Glad you didn't break your TB while doing these tests either.
Old 11-21-2006, 11:04 PM
  #63
DrX
DrX's Avatar
Originally Posted by moregrip
Outstanding DrX, how do we replicate the circuit? are you happy with the outcome?
I'm going to go over all the circuits, resistances and voltage values later this week and see how it can be best simplified. Not sure what is connected to what right now as I had to play around with the circuits to optimize the ranges as best I could for sensor correlation. Luckily one of the high refs was a little higher than the other and that helped me out a little.
I do have the sensors moving in their stock directions and I'm using the 02 TAC module.
The real test will be when I bolt the TB back on the truck.
Old 11-21-2006, 11:18 PM
  #64
DrX
DrX's Avatar
Thanks guys. It was a little tense when I soldered the wire onto the 1.0mm wide bit of gold trace at the end of the potentiometer for sensor 1. Then I went to close up the TB and the wire ripped the trace right off the board. Well solder wont stick to that black film. Do you know how long you have to hold a wire perfectly still until silver epoxy sets? Luckily no wires will have to be attached at that point for this to work with an 02 TAC module.
Old 11-22-2006, 02:48 PM
  #65
04sierra's Avatar
I'm glad to hear that there may finally be a fix for the 90mm TB mod. Great job DrX!
Old 11-25-2006, 01:14 PM
  #66
DrX
DrX's Avatar
Put everything back together yesterday then I noticed that the blade was sticking a little in the fully closed postion after bolting up the TB. So I pulled the TB off again to adjust it. Then I thought of another circuit board mod so I cracked open the TB again. Full range of TPS1 is now 0.5 - 4.1V so at 3.9V I should be slightly more open than the stock 78mm TB that has a range of 0.5- 4.2V on TPS1.
I'll finish up the write-up later today or tomorrow after I get a chance to drive it.
Old 11-25-2006, 01:19 PM
  #67
Adkoonerstrator
XLR8NSS's Avatar
Could these wire/resistors be attached outside of the TB, maybe a plug and play unit with a few stock connectors on it?
Old 11-25-2006, 01:27 PM
  #68
Bill Reid's Avatar
Wonder if this would also help by big dead spot?... as in the 1st 30% of throttle is useless (again). I used BlownChevy's TPS Max vs RPM vs % Max Available Torque table he suggested and it worked the first test drive... after that it "learned" and went back to the dead 1st 30%. I tried removing all of the torque management... no dice. I guess there is something else regarding the 06's that just does not correlate with the 02-05 trucks.
Bill
Old 11-25-2006, 01:38 PM
  #69
That's what I would want.
If this was a plug & play mod, then it would be worth it. Though I'm just not seeing $800 being worth it for a 90mm TB mod that doesn't work properly.
Jim
Old 11-25-2006, 03:29 PM
  #70
I AM A MOTHERF*CKER
TurboBerserker's Avatar
As soon as I see what all is involved in DrX's mod, I'll look into a plug and play circuit, but from what I read I don't believe it's a plug in type of mod -- which isn't say the solution can't be made easy, just probably no black box to put between two plugs kind of thing.
Quick Reply: Physical Range of 90mm LS2 vs 78mm TB
