Pics of who's running kb racing turbo kit
Old 03-22-2013 | 02:44 PM
  #81
nonnieselman's Avatar
Originally Posted by farmallcub
New guy here.
I just got my kit (no intercooler) from Kyle and was wondering a few things.
This is my first jump into modifying anything since 1978.
2010 Silverado 4.8
So, I completely understand the turbo concept and function. But could use some info on things like.
Where's the best place to pick up oil and return it?
There is a Oil Port Boss above the oil filter. Drill and tap that 1/8"-28 and put a adapter in it to -4 for you oil feed. Return can go to the front cover or oil pan. which ever you want.
What breather modifications/changes are made?
What are you calling a Breather?
Tips & tricks.
O2 sensors. Do you eliminate the rear set?
Yes
My tuner (Blackbear) will do whatever is needed to the PCM.
I have a turbo blanket and wrap. Should I wrap the hot pipe from the left bank to the right manifold?
yes, wrap all the hot side.
For now I'm going to use the stock air box with a K&N drop in.
im using the stock airbox and it works great for low boost/towing
I could use a couple pictures (of the smaller details) and I will take many while installing.
Thanks
There ya go
Old 03-22-2013 | 03:06 PM
  #82
farmallcub's Avatar
Wow, Thanks!
PCV
Old 03-22-2013 | 03:43 PM
  #83
Wow, Thanks!
PCV
Ahh.. yes.
Do you know where the hose that connects the passenger side valve cover to the Throttle body?
I capped the hose barb on the throttle body. Ran the hose from the valve cover thru a catch can and then to my air filter box.
Old 03-22-2013 | 05:03 PM
  #84
WICK3DxGATA's Avatar
not trying to steal the thread but does is anyone having problems getting to the kbracing website. it keeps ssaying bad request when i try and go to it.
Old 03-22-2013 | 05:09 PM
  #85
ZO6Ted's Avatar
Same thing. I'm sure it will be up by Monday if not sooner.
Old 03-22-2013 | 05:52 PM
  #86
kbracing96's Avatar
I took the website down, gonna go with a different company and might be a bit before its back up. Any questions, just pm me
Old 03-23-2013 | 04:56 PM
  #87
farmallcub's Avatar
OK, I see the bungs for O2 sensors on the crossover pipe and manifold.
What is the additional bung on the downpipe for?
Where does the extra spring shipped with the wastegate go?
How do you adjust the wastegate?
Is the extra spring shipped with the bypass a different spring rate?
Sorry if the questions seem simple to you but I want to make sure I understand everything.
Attached Thumbnails Pics of who's running kb racing turbo kit-3-23-2013-5-48-10-pm.jpg
Old 03-23-2013 | 05:04 PM
  #88
GMCtrk's Avatar
The bung in the downpipe is for a wideband o2 sensor.
Extra spring for the wideband is probably a stiffer spring. If it's a JGS wastegate, I believe the spring that comes in the wastegate is the light spring meaning lowest boost level.
As for the oil feed, I'm using the WJMark billet adapter. Can be had on ebay for about $20 shipped. Oil return is on the passenger side of the oil pan under the starter area. I didn't like the idea of returning to the front of the pan, too close to the balancer and AC stuff.
Old 03-23-2013 | 05:30 PM
  #89
farmallcub's Avatar
OK.
Now, I understand that there are four sensors, two pre-cat and two post.
Looking at the sensor parts online, they are a four wire sensor. Isn't that (four wire) a wideband sensor?
How would I tell the computer to look for a third sensor (the wideband bung in the downpipe) or do I plug that hole?
I was going to have my tuner eliminate the two rear O2 sensors.
Thanks
I'm used to dealing with turbos and air on larger engines (3,000 to 9,400 CID).
They are bigger but simple. One wideband O2 per bank for AFR control, that's it.
Old 03-23-2013 | 06:05 PM
  #90
Atomic's Avatar
I have a gauge for that
For the JGS gate, the larger OD spring is the softest and gives the least boost...the smaller one is stiffer and gives more boost....for more boost use both springs with the little one inside the larger one.
For O2s, you use the front o2s in the exhaust ports and you delete the rear o2s from the computer (any tuner can do this). The wideband is not through the pcm, it is a standalone wideband controller. FWIW, all widebands are at least 5 wires; narrowbands are 4 wires. I personally like the NGK because the sensor and analog output are really good (but the display sucks).
Quick Reply: Pics of who's running kb racing turbo kit
