Pinging
Pinging
My truck is pinging under boost from 4k on up. I am running a walbro 255 intank pump. I have a Vortech V2 supercharger with a 2.87 pulley. Running 13lbs of boost. I have 75lb injectors, 90 mm throttle body, FLH, Tuned by Blackbear performance. Do I need a different pump?
Either the tune has too much timing or not enough fuel, also as stated above you could be running out of the supply of fuel meaning check to see if your fuel presure drops much. i had a pinging problem and i got a dyno-tune and cleared it all up she was running alittle lean and we pulled some timing. she runs great know, but the real test will be this summer in 115 degree dry heat of arizona. good luck!
I pick up about 2 degrees of KR at 5500. I can't hear it but see it on Hpt.
I'm also running 13psi and finding out 91 pump gas cannot support that much boost. I have a meth kit that I'm installing. My fuel pressure drops off at higher rpms but afr hangs in there at 11.8.
