Plug wires with flipped truck manifolds?
Old 09-13-2012, 11:39 PM
13 Second Truck Club
LS1FREEK's Avatar
Thanks!
Edit- DAMN! They're expensive!!!
Old 09-13-2012, 11:52 PM
LS1FREEK's Avatar
Originally Posted by black00chev
I dont see why a set of wires like what Supercharger Connection sells wouldnt work just fine?
like these
The problem is there is literally less than an inch room between the manifold and the head/valve cover, the wires are nearly impossible to keep from touching the manifolds, not the greatest angle here but u kinda get the idea
Old 09-14-2012, 03:04 AM
GFYS and STFU
Spoolin's Avatar
I know there's a few people on here who run their coil packs basically on top of the engine mount and extend the engine harness so that it reaches. It's the cleanest solution I have found to running plug wires away from the hot side of our turbo systems.
Old 09-14-2012, 06:44 AM
LS1FREEK's Avatar
Soounds like a much cheaper alternative lol! Think you can find me a pic of this? I'm very curious as to where they actually bolt it to.
Old 09-14-2012, 07:46 AM
kush killer's Avatar
as am i ! this will also be a problem im faced with in the very near future
Old 09-14-2012, 09:27 AM
Mod with training wheels
smokeshow's Avatar
Originally Posted by o2camaross
How does that gasket like the exhaust back pressure?
Old 09-14-2012, 09:45 AM
I have a gauge for that
Atomic's Avatar
Same type of gasket I used with **** tons of back pressure, worked fine
Old 09-14-2012, 11:18 AM
GFYS and STFU
Spoolin's Avatar
Pictures I don't have as I've only seen them in person and never thought of takin any pictures but I can tell you which members probably have them and who makes it.
Nelson is the speed shop that started doing it and he does it to most of the turbo trucks that he builds. I think his screen name on here is FarmTruck.
You can also PM tarinup since I believe Nelson helped build his turbo kit. They might have some pics of it for sure.
Old 09-14-2012, 12:43 PM
vicalma03's Avatar
I was gonna go the "build your own wire" way but in the end I bought a set of plug wire heat sleeves and ran them in stock form. The wire isn't touching any part of the manifold but only time will tell if its gonna work or not. I'll get some pics tonight
Old 09-14-2012, 12:44 PM
vicalma03's Avatar
Plus they are only 30 shipped !
Quick Reply: Plug wires with flipped truck manifolds?
