Plug wires with flipped truck manifolds?
#21
Jake, they are holding up just fine. I have about 3,000 miles on it now and no problems that I can tell. I want to get a gauge on the hot side to measure back pressure and also get a gauge on the pre-intercooler side to measure pressure drop
#22
Slowest turbo build ever!
Damn, that manifold is pretty tight to the head. Tighter then I thought it would be. I think I know what Spoolin is talking about. I remember seeing pictures on here of someone that made new, or reused the coil brackets and had them mounted just above the oil pan on each side.
#29
That will work for a little while but not for long. I had the lava heat wraps on my wires and they still burnt up real quick. I had my stock coil pack mount ziptied to the motor mount and just used stock wires and ran them up the the plugs. Got the harness extension from Nelson.
#30
Well my plug wires burnt up!! I had 2 layers wrap on the manifolds and 3 on the wires! It'd work just fine if the wires weren't actually touching the manifolds but I guess I'll just have to bite the bullet on the high dollar custom MSD's!!
