possible boost issues
Old 04-21-2012, 07:07 PM
topgun10x's Avatar
Default possible boost issues
this might be a silly question, i am running 12lbs. with a procharger. it hits 12lbs when at 5000rpms (red line for now) then shifts and drops to 6ish lbs and climbs as the rpms do. so the question is is there a way to maintain 12lbs all the time once at WOT.
Old 04-21-2012, 07:34 PM
ak2007r6's Avatar
A stall converter will help keep the RPM's up while getting on it but other than that I can't think of to much.
Old 04-21-2012, 07:43 PM
CC05's Avatar
A ProCharger without a stall is a whole world's difference than a ProCharger with a stall. Circle D, Yank, etc. Check them out.
Old 04-21-2012, 09:03 PM
quicksilverado's Avatar
Switch to a turbo.
Old 04-21-2012, 09:05 PM
ak2007r6's Avatar
pretty sure a turbo would have blown it up just the same with a tune that's out of wack
Old 04-22-2012, 06:02 AM
topgun10x's Avatar
i have a 2000 stall in there now. i want to keep it street friendly. i see alot of you running 3000 -3500 plus stalls, isn't that reving the crap out of it just trying to take off from a stop in normal driving.
Old 04-22-2012, 06:03 AM
topgun10x's Avatar
it does have a tune from sniper but i am going to get it redune because it is not right, it runs way to rich.
Old 04-22-2012, 06:31 AM
11 sec. Truck Mod
TIM Z's Avatar
Originally Posted by quicksilverado
Switch to a turbo.
Im sure this was said beacuse of the difference between a turbo and belt driven supercharger make boost.
Its good your rich so your on the safe side, but a live person tune will def. help dial your combo in more.
A performance torque converter will help you stay in a " better" rpm range that will compliment where your blower is strongest/ in turn lessining boost drop and helping your combo get into and maintain max boost.
Old 04-22-2012, 06:58 AM
nonnieselman's Avatar
If your running a 60E, the yank TT3000 is a nice tight converter that you can DD and almost not notice it.
Also gear change would help some since those prochargers like rpms.
Old 04-22-2012, 09:48 AM
topgun10x's Avatar
i think rich is an under statement. it is lower than 10:1 from what my one that plugs in to the exaust says, im wanting it to be around 12-13:1 when redune. with 9:1 comp. is this to high?
Quick Reply: possible boost issues
