possible boost issues
Old 04-22-2012, 09:57 AM
ak2007r6's Avatar
I would think around 11.8 is where you want to see it for WOT. 13 seems a little lean for boost and WOT.
Still getting into tuning though so will let someone with more experience chime in
Old 04-22-2012, 09:58 AM
lglowe's Avatar
Way to high. You wanna be around 11.2-11.7 afr under boost
AndysC3's Avatar
Have you thought of a wastegate with a boost controller? Just pulley down to about 18psi and set the controller to 12psi. the wastegate will bleed off the extra boost. Boost might drop a little but will come back quick. Just search for procharger and wastegate. This is what I'm planning to do once I get my procharger. And you want your afr around the 11.5-11.8. 12+ is way to lean with that much boost.
Old 04-22-2012, 10:04 AM
I have a gauge for that
Atomic's Avatar
Thats normal, prochargers run at a multiple of the engine speed. The way to "fix it", as was mentioned, is to get a turbo.
Old 04-22-2012, 01:09 PM
foose04's Avatar
I think another option would be gets some valve springs and tune to cover a 6k shift. That would keep the RPM's/Boost up on the shifts.
Old 04-22-2012, 01:17 PM
Atomic's Avatar
Also, simply running a smaller pulley and using a wastegate "works", but has negatives in regards to impeller speed (ie, max engine rpm) and supercharger efficiency.
Old 04-22-2012, 01:49 PM
quicksilverado's Avatar
Originally Posted by ak2007r6
pretty sure a turbo would have blown it up just the same with a tune that's out of wack
What? When did he mention anything about blowing up? Once a turbo spools it maintains boost. Unlike a procharger that is rpm dependent for boost.
Old 04-22-2012, 01:54 PM
ak2007r6's Avatar
He never did.. honestly I think I had my mind on another thread where the guy was self tuning for the first time on a boosted motor and got that thread and this one confused...
sorry bout that, not sure what I was thinking LOL
Old 04-22-2012, 03:29 PM
topgun10x's Avatar
thanks for the input. im staying with the procharger for sure. the kit came with a 8# pully org. and i opted to put a 12# on. the org. red line is still 5K rpms. when it gets tuned again i want it to go to 6K if they can with will put the boost to 16#s. i was told the engine would be good to 7K and handle 16#s. so at 7K rpm would put me at 20#s. lol would be nice but dont think it will hold not to mention the 42# injectors, i dont think they will be big enough for that.
Old 04-22-2012, 03:30 PM
topgun10x's Avatar
oooohhhh sorry by the way going put do a meth kit also.
Quick Reply: possible boost issues
