possible boost issues
I would think around 11.8 is where you want to see it for WOT. 13 seems a little lean for boost and WOT.
Still getting into tuning though so will let someone with more experience chime in
Have you thought of a wastegate with a boost controller? Just pulley down to about 18psi and set the controller to 12psi. the wastegate will bleed off the extra boost. Boost might drop a little but will come back quick. Just search for procharger and wastegate. This is what I'm planning to do once I get my procharger. And you want your afr around the 11.5-11.8. 12+ is way to lean with that much boost.
sorry bout that, not sure what I was thinking LOL
thanks for the input. im staying with the procharger for sure. the kit came with a 8# pully org. and i opted to put a 12# on. the org. red line is still 5K rpms. when it gets tuned again i want it to go to 6K if they can with will put the boost to 16#s. i was told the engine would be good to 7K and handle 16#s. so at 7K rpm would put me at 20#s. lol would be nice but dont think it will hold not to mention the 42# injectors, i dont think they will be big enough for that.
