Prefered Meth Injection Kits
#31
Bringing this thread back from the dead, im planning on making a DIY meth kit.... It makes perfect sense to put the meth nozzle before the iat sensor but i belive the one i have is not able to get wet! Does anyone ever mount it after the sensor? What size jets are guys running with 20+ boost and 1000-1200 hp?
#32
I curious If spraying meth/water in the engine. Cause parts will rust inside the engine?? Is it a cool way to make more power ?? if it fail and the meth kit doesnt work but tune is still set for one, it can blow engine ?? if they had a lot of timing added because of the meth kit, an then the meth pump fail is it will be hurtful the engine ??
#35
I ran a devils own and didnt have any problems for a couple years. Used -30* WWF for awhile. Then switched over to VP1 straight methanol. Towing it helps a good bit, IATs never went over 100*
