Problem with new fuel system
Old 05-09-2011, 11:31 AM
Gadgetized's Avatar
I would start out by not going through the Bosch when it isnt running. If that doesnt correct your problem, I would take the regulator apart. I have used the braided line, and a little piece of rubber came off, and got stuck in a needle/seat of a carb. The same thing might have happened to you, and if there were a small piece of rubber between the regulator valve it could cause your problem. Just a thought.
Old 05-09-2011, 12:28 PM
MikeGyver's Avatar
Originally Posted by Gadgetized
I would start out by not going through the Bosch when it isnt running...
I thought about that, but with the extra check valves, there is always the added problem of diagnosing them if something else happens with the pressure in the future.
Old 05-09-2011, 06:00 PM
vortecyota's Avatar
He ran both constant today and it worked fine. When we get the trans back from FLT I will remove the Bosch and build a temporary bypass hose. This should eliminate the possibility of pushing thru the Bosch causing this. Thanks guys, will report back when we get it back on the road.
RONIN LSX
08-10-2015 04:45 PM
TAPyvehc93
08-08-2015 06:35 PM
MS3Z
07-30-2015 06:17 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Problem with new fuel system
