Procharger cold air intake set up ...pics
#23
Did the tuna last night and its just plain Nasty now ...I have an excellent tuner who specializes in Forced Induction at hi shop ...there is always a turbo truck or a GN in there on any given day ...man that guy can tune...after about 14 WOT passes my IAT where up in the 112's also he wants me to get a map froam Colbat SS turbo and install it just to tweak it a little more...NOT that it needs it ...this truck hits boost instantly...he is safely running a variable timing program with very safe Knock sensor timing adjustmnets its hitting in the 20%s if you can beleive it with 0 lean and no meth ... oh here is a pick with the opther end of the CAI that plums down with a block / holder brackett i made ... i did also vent my crankcase with a nice Harley venter thats mounts to to the intake but i left my BOV running back through the charger i thouight about and the extra sucking from the charger may help it ope faster smoother so i left it ...anyway truck is a totally nasty now may go to the new track this weekend just to see what its doing
#24
#25
I have the smaller 3.70 9lbs ... turning 55k verses 65k max impeller ...we tried to read it through the map/KPA but it goes too high unreadable past 7lbs thats why my tuner wants the Colbat map...i have as of yet iam still unsdeciced on Gauge size location ...i dont really want to show my gauges ...id like to be a sleeper as much as possible...
#27
#30
24 pound injector (BSFC of 0.57) and at 90% duty cycle can support 303 hp.
24 pound injector (BSFC of 0.57) and at 95% duty cycle can support 320 hp.
A 24 pound injector at 85psi will now flow the same as a 35 pound injector
A 35 pound injector can support 453 bhp at 95% duty cycle.
I put large Robin gauges for pressure and flow and 55.psi was the magic number at peak flow with a base of 4.05 per psi
so 44lbs @ 40psi = 44lbs ,(44lbs @ 55psi = 60lbs ), if they will flow...
so if the injectors will flow and not seal leak we where good with 44's and it worked
what psi and flow rate are you running / return or not ..iam huge beliver in return style
