Procharger F1R LSX 50mm Cog Drive Kit
Old 01-04-2010, 08:45 PM
  #51
jasond26's Avatar
The kit is designed around the f-body balancer. You could probly have someone machine a new bracket spacer for a truck balancer but there would be no point considering the full kit comes with new brackets for the alternator and power steering.
Old 01-04-2010, 09:10 PM
  #52
MFIC's Avatar
This might help showing why truck accessories wont work http://www.procharger.com/pdf/COG_LSx.pdf. The entire truck alt/power stering bracket is removed to fit the blower bracket. And this is the difference in pulley spacing from the block.
Old 01-04-2010, 10:04 PM
  #53
shawnss's Avatar
Wow. your truck is just sick. not only does your truck sound like a beast. it is very clean. looks like you'e taken care of it and done everything right. oh by the way Arrival blue trucks are the fastest. LOL
Old 01-06-2010, 01:15 PM
  #54
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Do you have the spec's needed to reclock the head unit like yours? Thanks
Old 01-06-2010, 06:26 PM
  #55
MFIC's Avatar
This PDF has all the specs click---->http://www.procharger.com/pdf/COG_LSx.pdf
let me know if you need anything else.
Here is a basic overview
Old 07-09-2010, 04:29 AM
  #56
Low_LSX's Avatar
Any updates?? How's the truck running? Also What 6 rib belt did you use for the AC and other stuff? Thanks.
Old 07-19-2010, 09:43 PM
  #57
nxredsled's Avatar
Do you have A/C and if so what di you have to change? looking into the serpentine setup for my 5.3 was wandering want to keep my A/C
Old 07-20-2010, 08:21 PM
  #58
Swerve7rpm2000's Avatar
Hey im looking at a similar setup but its gonna be a 408 stroker with the D1SC..... i talked to a guy who wants to build it and i just wanna confirm some of this..... i have a 255 GPH external walboro fuel pump on it and he said i wont be able to just duel that kind up to get the right amount of fuel i need, also said 60# injectors, i currently have 6an running to the fuel rail into one side and to other rail then to regulator.... can i just run another pump and do them one to one rail and one to the other than to the regulator with 6an w/ a 8an return line?
Old 07-20-2010, 08:28 PM
  #59
and one more question i got quoted 4,700$ for the D1SC lsx setup..... is this reasonable or anyone know of a place that is?
Old 07-20-2010, 11:54 PM
  #60
8 Second Truck Club
Blown06's Avatar
You might consider starting a new thread for all these questions.
Quick Reply: Procharger F1R LSX 50mm Cog Drive Kit
