procharger gauge setup
Old 09-05-2011, 09:51 PM
I have a gauge for that
Atomic's Avatar
boost, afr, fuel pressure, oil temp...
Old 09-05-2011, 10:31 PM
02'Z71ONDUBZ''s Avatar
Will a turbo heat the oil up enough to cause issues? Ive never thought about this, if anything I would have thought an EGT would be the next choice for a turbo setup.
Old 09-06-2011, 08:48 AM
Atomic's Avatar
That is what im wondering, especially under high boost conditions. EGT isnt as important on gas engines as it is on diesels.
Old 09-06-2011, 06:57 PM
TimDave217's Avatar
the reason i was wondering about the oil press. gauge is because of the oil drain on the turbo, I have some knowledge of turbo's but never have owned anything turbo'd thats why i was wondering if the oil drain had enough press. going through it to cause problems.
Old 09-06-2011, 07:36 PM
Atomic's Avatar
oil drain should have basically no pressure, thats why guys use huge drain lines. I use a -4 feed and a -10 drain...
Old 09-06-2011, 07:57 PM
Mod with training wheels
smokeshow's Avatar
Only causes issues if you don't change the oil regularly enough, or if the oil lingers in the turbo due to a poorly set up return line. Either way, the heat from the turbo is going to reduce the life of your oil. I believe foose04 posted up a pretty good article about that a few weeks back.
Old 09-07-2011, 07:18 PM
TimDave217's Avatar
yea i've seen the article, and thanks for clearing that up i assumed it wouldn't but then thought about it and wondered if there was enough pressure going through the oil drain to do some damage. its cleared up now
GXPJAY
02-13-2022 08:15 AM
chopperloco
07-10-2016 10:45 PM
D1SCSS
01-25-2016 10:14 PM
thunder550
10-08-2015 04:53 PM
Quick Reply: procharger gauge setup
