Procharger guys with large FMIC in upper grille, input needed. PCM location?
11 Second Club
I am finishing up the build on my RST. I bought a P1SC and bracket set off of eBay a few months ago. Tomorrow Summit should be dropping off my Pro-Flo XT intake so I can finish up the intercooler piping. Right now I have the 31"x12"x4" intercooler mounted behind the main grille on my Sierra. The fmic outlets line up good and with some trimming I can fit the 3" piping in between the headlights and turn signals. I will be running the air filter over to the passanger side and later on I plan to make a air box. The only real issue I am running into with this large fmic and the 3" piping is on the drivers side outlet. The stock PCM location is right where the charge pipe off of the blower outlet needs to run. Even just to be able to bolt the blower in place the PCM had to be moved forward. So the PCM has to be moved and I wont really want to mount it any lower or have to extend the wiring harness to relocate the ECU. So the easiest way to solve the problem was move the battery and put the PCM in the stock battery location. The battery fits perfect against the firewall and has just over a 1/4" of clearance with the hood closed. Only downside is the firewall to fender brace would not be able to be used with the battery in that location. So all I would have to do is make a mounting plate and tie down and run the battery cables over there. Then I dont have to touch the PCM harness. Just wondering if anyone has done a similar setup and where you moved the PCM to allow the intercooler piping.
Sorry for the shitty cell phone pics but I wanted to show what I was talking about.
![](http://i143.photobucket.com/albums/r136/joekeating1/4-9.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/1-12.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/3-9.jpg)
![](http://i143.photobucket.com/albums/r136/joekeating1/2-11.jpg)
Just purchase a 99-06 Diesel 2nd battery tray. Goes right where your trying to move your battery. Do a search and you'll find the two part numbers you'll need.
2nd and IMO, better choice is to mount the FMIC to the bottom of the radiator support. You'll have to notch the bumper supports since your running the 31" vs the 27" which just fits. You'll get plenty of airflow and it won't block your radiator airflow. Then you'll just have to move the PCM over an inch or two and it will be a lot easier to route the cold piping.
![](http://i252.photobucket.com/albums/hh26/rick_vor/2003and2004P-1SCinstall50707011.jpg)
![](http://i252.photobucket.com/albums/hh26/rick_vor/2003and2004P-1SCinstall50707024.jpg)
Rick
Rick
Rick
Rick
Baltimore Whore
Hmm I think you might have been better off going behind the valance.. Seems you wouldn't have been having to move stuff around. I must say I like the way the front of your truck looks. ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i6.photobucket.com/albums/y216/mangler0075/blower/005-5.jpg)
![](http://i6.photobucket.com/albums/y216/mangler0075/007-2-1.jpg)
Rick
Baltimore Whore
Rick what is the quality on them ebay kits?? I ahve thought about getting one, but wasn't sure if they are nice and sturdy with a good side wall... I buy alot of my stuff from treadstone
11 Second Club
I got the Edelbrock Pro-Flo intake, Pro-Flo rails, 60# injectors, LS2 90mm T/B and X-Link adapter. So I am all set to finish up the intercooler piping and mount Tial 50MM bov. Then all thats left is install the fuel pump and I can finally see how this setup runs.
Thanks for all the input.
