Procharger has the Coolest IAT?
Old 11-01-2007, 09:42 AM
  #31
Notorious BIG
Holty's Avatar
The point of having your IAT sensor read actuall air temp as it enters the intake is so that it can be the most acurate. I have my IAT timing table starting to pull timing at 98degrees. It is a tad over kill but hey its not hurting anyting. Oh I see you are spraying meth too? Where is the Meth injected at on your setup? You should really move that IAT sensor...
Exactly, its not just about timing, its about being accurate. There are ALOT more things to consider that need IAT for calculation besides timing.
Old 11-02-2007, 02:18 PM
  #32
11 Second Truck Club
sprayinLS1s's Avatar
Originally Posted by zippy
I highly doubt a Whipple has the lowest IAT.
no whipple doesnt have the lowest iat, but damn if it dont make the torque. id say turbo i-cooler and water/meth... or spray the **** out of it, guarantee iat's will drop and almost no heat soak, my blower is about same temp after a run as it is before, im also spraying through the s/c (about 150 shot)
madmann26
04-29-2020 09:17 AM
Mr. Chainsaw
10-18-2015 08:00 PM
JordanH
10-03-2015 03:59 PM
murderedSS
09-27-2015 10:16 PM
TAPyvehc93
09-17-2015 10:10 AM
Quick Reply: Procharger has the Coolest IAT?
