Procharger has the Coolest IAT?
#31
Notorious BIG
The point of having your IAT sensor read actuall air temp as it enters the intake is so that it can be the most acurate. I have my IAT timing table starting to pull timing at 98degrees. It is a tad over kill but hey its not hurting anyting. Oh I see you are spraying meth too? Where is the Meth injected at on your setup? You should really move that IAT sensor...
#32
11 Second Truck Club
no whipple doesnt have the lowest iat, but damn if it dont make the torque. id say turbo i-cooler and water/meth... or spray the **** out of it, guarantee iat's will drop and almost no heat soak, my blower is about same temp after a run as it is before, im also spraying through the s/c (about 150 shot)
TAPyvehc93
09-17-2015 10:10 AM
05, compressor, crappy, gto, high, iat, idle, injection, location, nonintercooled, normal, procharger, prochargeriat, sensor, silverado, water
