procharger help
Old 12-25-2011, 12:57 PM
redrider105's Avatar
30 day warranty
Old 12-25-2011, 01:05 PM
Baltimore Whore
Mangled03gmc's Avatar
You do know that even after they replace that stuff that it could still leak some oil out the output shaft.. That is not a warranty issue either.. Some of them leak some of them do not.. That is direct from the procharger people..
Old 12-25-2011, 01:17 PM
Yes from the reading I've done on here that's what everyone has said but mine was a serious leak. I guess ill see if it still leaks after I get it back
Old 12-25-2011, 01:41 PM
Baltimore Whore
Ok, my P1 leaked a little even after I replaced the output shaft seal, even this new D1 hints a little bit now and then...
Old 12-25-2011, 03:16 PM
Do you think it was slinging oil on the belt? I don't know what else it could be. Gonna relocate the pulleys and replace belt. Well see if it helps
Old 12-25-2011, 04:10 PM
Baltimore Whore
Na mine was not leaking outside the unit, just through the output shaft..
Old 12-25-2011, 09:37 PM
ok mine was leaking inside pipe, on the bottom and on the front behind pulley
Old 12-26-2011, 12:21 PM
phasemaster1's Avatar
Originally Posted by redrider105
30 day warranty
Boy that sucks!
That blows. Hey I changed your oil pan gasket you owe me a gazillion dollars by the way it still might leak. good luck.
Old 12-26-2011, 12:38 PM
Baltimore Whore
^^^^ Yah I know.. It is Bs but wth they got you where they want ya
Old 12-27-2011, 09:33 PM
yeah thats how i feel. got invoice today they said it will be here thursday.
Repair of P1SC PROCHARGER 10:0
1.0
$645.60
-CS03CI-24SS / 10-24 X 1-1/2" SS SHCS (FR COVER)
8.0 -PC000C-025 / TRELLEBORG TEFLON SEAL - "SC" 1.0
-CS04CI-8SS / 1/4-20 X 1/2" SS SHCS (COMPRESSOR) 6.0
-RMA.PAIDREPAIR / PAID REPAIR 1.0
-PC000C-031 / SC "D" "F" FRONT OIL SEAL 1.0
-PC000C-195 / 23.75" O RING - "SC" SERIES 1.0
-PCB24C-000 / 204 BEARING- A/C 1.0
-PCB25C-004 / 205 BEARING- A/C 1.0
-PCT01C-000 / SERIAL TAG UDRIVE BOLT/RIVET-SS 2.0
ME001A-001 / SC OIL BOTTLE (6 OZ-FILLED) 1.0
ME010I-001 / ATI FOAM ENC- 9" UNIVERSAL 1.0 $15.00
ME007I-003 / 16 X 16 X 16 1.0
FREIGHT / FREIGHT CHARGE 1.0 $38.00
Total $698.60
madmann26
04-29-2020 09:17 AM
murderedSS
09-27-2015 10:16 PM
MOBBN
09-22-2015 08:07 PM
murderedSS
09-22-2015 03:53 AM
Justin87gn
09-10-2015 12:06 PM
Quick Reply: procharger help
