Procharger set-up
Old 08-06-2007, 02:36 PM
sharpshooter's Avatar
Superado what would happen if you leave the pcv valve and hose all in place [like stock] and only vent the crankcase at the oil fill hole.I also heard of tapping hvac[I hope this is the right abbreviation] line for vacuum.Is this good info.?
Old 08-06-2007, 05:07 PM
I finally got my install manual in the mail about 5 mins. ago.Now I understand all of the responses much better.They[procharger] leave the pcv alone [all stock] and vent off the passenger side valve cover and block the tb connection.What if I don't touch any stock connection [even leave the tb line hooked up] and only vent from the oil fill hole?
Old 08-06-2007, 05:24 PM
ranwalk's Avatar
If you dont block off the tube at the throttle body you will pressurize the crankcase.
You also need to check and see if your pcv valve is a fixed oriface or a plunger style. The fixed oriface could lead to crankcase pressurization also.
Old 08-06-2007, 09:54 PM
How can I tell which pcv I have?
madmann26
04-29-2020 09:17 AM
murderedSS
09-27-2015 10:16 PM
MOBBN
09-22-2015 08:07 PM
murderedSS
09-22-2015 03:53 AM
Justin87gn
09-10-2015 12:06 PM
Quick Reply: Procharger set-up
